Опрос 2024
When new albums added, artist name doesn't add in with alphabetical order
Topic: When new albums added, artist name doesn't add in with alphabetical order (Read 1098 times)
March 06, 2021, 06:24:19 »
Kakaredesu
Hello good people. I am new to AIMP but enjoying so far.
I have one problem though. When I add new albums to my music folder, artist doesn't appear in the alphabetical order under the "Artist" grouping. Also it's just like that with my custom grouping which groups by "Artist-Album". If I delete all media from database and update from all over again new artist gets into alphabetical order. Is there something I do wrong? Can I add new albums with the artist added to the grouping in alphabetical order?
In the added picture for example the album with the "Herskin" artist is newly added. And "Herskin" is added to the end of alphabetical list of Artists. Every other artist is in alphabetical order, except for this one. I tried with many other albums it just works like that. Just updating doesn't work I need to delete all media from database and update from 0 every time.
I am using v4.70 build 2242
Thanks!
Last Edit: March 06, 2021, 06:39:41 by Kakaredesu
Re: When new albums added, artist name doesn't add in with alphabetical order
March 06, 2021, 09:29:11 »
Супермен
Карма: +2928/-56
Check settings of grouping template.
March 06, 2021, 14:54:50 »
Kakaredesu
Thanks Artem that worked, I got it now.
the icon which i'm hovering over should look like this in my case. If someone else is searching for the same answer that should do the trick.
Last Edit: March 06, 2021, 15:06:08 by Kakaredesu
