AIMP for Android v4.00
Break up .APE file
Topic: Break up .APE file (Read 990 times)
Break up .APE file
December 13, 2020, 16:14:21 »
Herring
I would like to know if it's possible to break down an .ape file into individual tracks. I tried opening the .ape file with AIMP and then selecting convert to mp3. All the individual tracks are displayed in the window, but the .ape file just was converted to a single .mp3 containing all tracks.
Is there a way with AIMP to do this?
Re: Break up .APE file
December 13, 2020, 18:07:10 »
Супермен
Карма: +1265/-179
Very big button on right bottom side for you
December 13, 2020, 18:24:54 »
ㅤ
Карма: +76/-1
Hello and welcome to the forum,
Yes, you can do it this way:
By the way, you need the CUE file.
December 13, 2020, 19:23:22 »
Herring
Thank you ᏦᏁᎢᎵᏫ and Soolo. That worked perfectly.
I was sure it could be done, I was just confused with the source --> file options.
Спасибо
Break up .APE file
