Опрос 2024
How to add ascending/descending to sort template?
Topic: How to add ascending/descending to sort template? (Read 875 times)
October 27, 2020, 16:52:50 »
thoste
I defined as sorting template
%FileParentDir%Mark%LastPlayDate%LastPlayTime
When I click it in the bottom bar of a playlist then the songs are sorted but in ascending order.
That means songs with only 1 star are on top of the list.
I always have to click additionally "invert" to get the opposite order.
That is tedious and unnecessary.
How can I tell AIMP in sort template to sort it immediately in descending order (=5 stars Ratings at the top)?
It should something like
%FileParentDir%Mark%LastPlayDate%LastPlayTime%DESC
Re: How to add ascending/descending to sort template?
October 27, 2020, 19:51:33 »
Супермен
Карма: +2928/-56
Use the %! before the macro that must be in descending order
