AIMP для Windows
Ошибки / Замечания
Обработано
[x] Problem with .oma files
Topic: [x] Problem with .oma files (Read 1183 times)
June 05, 2020, 12:20:36 »
serggo84
Hi,
I have a problem with some .oma files.
I have recorded a few songs with my Minidisc recorder in PCM mode. Files have .oma extension but AIMP cannot play them.
There is a message:
Code: -1 (FFFFFFFF)
Message: Decoder was not found for this format.
What is the problem that AIMP do not play them? I have read that player support .oma files. Is there some settings I have to do, or I have to download some plugin?
Thanks!
Last Edit: June 09, 2020, 00:36:24 by Artem
Re: Problem with .oma files
June 05, 2020, 13:16:38 »
Супермен
Карма: +2730/-48
Make sure that plugin FFmpeg is loaded
June 05, 2020, 15:12:41 »
serggo84
Hi,
In the attchment you can see that FFmpeg is loaded but files connot be played...
June 05, 2020, 15:38:57 »
Супермен
Карма: +1166/-166
Can you share this file for an analysis?
June 05, 2020, 18:05:04 »
serggo84
Hi,
At the following link you can download one of my oma files:
https://cloud.mail.ru/public/Lw4y/VjH9H1oCw
June 09, 2020, 00:36:16 »
Супермен
Карма: +2730/-48
Thank you, I have fixed the issue
Re: [x] Problem with .oma files
June 09, 2020, 11:46:05 »
serggo84
Спосибо
AIMP для Windows
Ошибки / Замечания
Обработано
