Планы на 2021 год
AIMP для Windows
Ошибки / Замечания
Обработано
[x] [2180] Small Glitch in Rating
Topic: [x] [2180] Small Glitch in Rating (Read 843 times)
April 25, 2020, 13:20:39 »
riderboy
I use the "Synchronize user defined ratings with tags of audio file" option in "Player" -> Music Library. The rating system works fine except that there is a mix a two rating systems used to store the rating value under the "RATING WMP" tag of the file. The 4 stars rating is stored as 192 following the 0 to 255 system. All other ratings values are between 1 and 5. The 192 rating value can be interpreted as 3.5 stars in other media players.
Last Edit: April 28, 2020, 09:33:19 by Artem
Re: [2180] Small Glitch in Rating
April 25, 2020, 19:30:49 »
Супермен
Карма: +2730/-48
What you mean under the WMP Rating System?
April 26, 2020, 13:15:27 »
riderboy
WMP Rating stands for "Windows Media Player Rating". This is a tag saved in the file metadata and that will be visible in Windows File Explorer (see first attachment). I think this tag is stored under "Rating WMP" (see second attachment - MP3Tag). By default, AIMP stores the rating information in the library database and it's not stored in the metadata of each file. However, it's possible to synchronize the AIMP rating with the WMP Rating in AIMP by ticking the option "Synchronize user defined ratings with tags of audio file". All ratings (WMP Ratings) are stored fine in the metadata of the file except for the 4-star rating that return the value 192 (following the 0 to 255 rating system). All other ratings would be between 1 and 5 (following the 0 to 5 rating system). Hope this clarifies this issue.
April 28, 2020, 09:33:14 »
Супермен
Карма: +2730/-48
Thank you, fixed.
Re: [x] [2180] Small Glitch in Rating
April 29, 2020, 12:54:56 »
riderboy
Awesome!
AIMP для Windows
Ошибки / Замечания
Обработано
