Is there a way to view the internal shuffle queue?
Could not get shuffle to work, just plays the next track. I do have the local media selected on album.
I have 7160 songs in the list and the program repeat many times the sames songs, sometimes 10 songs later since it was heard.
Is there any star rating / weighting that influences the random?
It impossible according to used algorithm, of course, if you not re-create shuffler's queue by toggling the "shuffle mode" button.
I have that feeling too, that some songs are playing too often and others less often, I toggle the shuffle mode sometimes for other tabs/playlist, so is it a problem?
Starts from v3.60 AIMP's algorithm does not allow repetitions while entire playlist will not be played, of course, if you have not interfere into playback queue (re-import the playlist, re-start the playback from any track in playlist) and does not toggle the shuffle mode
