Skin Editor, Skin Engine
[ skin-editor trick ] Remove the second line in the playlist section
Topic: [ skin-editor trick ] Remove the second line in the playlist section (Read 6406 times)
February 29, 2020, 22:19:21 »
Chivo
Карма: +7/-0
Hello dear friends, I want to
completely delete
the
second line
in the skin editor and in the
playlist section
where it displays the name of the track's, which includes song specifications such as format, bitrate, and song file details.
Only
display the name of the song and
do not
display the
second line containing
the format and bitrate. What do I need to do to remove the second line in the playlists and not display the song details such as format and bitrate in play-list section ?
thank you .
Last Edit: March 01, 2020, 01:08:51 by Chivo
Re: [ skin-editor trick ] Remove the second line in the playlist section
February 29, 2020, 22:52:48 »
Карма: +3176/-76
This information can be disabled on player's level.
March 01, 2020, 01:08:22 »
Chivo
Карма: +7/-0
Quote from: Artem on February 29, 2020, 22:52:48
Problem solved, thank you dear friend
