Планы на 2020 год
English pages
Tutanhomon
Hotkey for next track not always working
Topic: Hotkey for next track not always working (Read 946 times)
December 30, 2019, 17:44:04 »
akialyn
So I set the hotkey for next track to the right arrow and previous track to the left arrow.
When I first launch and select a song it works then if I do anything else in the program (double click another song) it stops working and I can't figure out how to get it back.
Any ideas?
Re: Hotkey for next track not always working
December 31, 2019, 01:11:36 »
Dreamer
Продвинутый
Карма: +11/-0
I have similar problem with up/down keys to change volume, with the skin "Gilly Matt&Glossy" skin.
OK, so it's also with Bliss 4K skin.
To reproduce:
- change skin to Bliss 4K or Gilly Matt&Glossy
- hotkeys up/down to change volume work good
- now enable playlist
- attach playlist to main window
- click any playlist item
- use up/down arrow keys
- playlist item focus is changed, correct
- click within the main window, or directly to volume bar
= playlist item focus is changed, incorrect, volume should be changed instead
Only if playlist is attached.
Mouse wheel works good, always, even if playlist is attached, over the main window it changes volume.
I think it could be the same bug.
AIMP v4.60 build 2156, Windows 10 64-bit 1909.
English pages
Tutanhomon
