AIMP for Android v4.00
Suggestions
DennoN
hotkeys jump to next track (F2) vs. follow cursor (automatic scroll of playlist)
Topic: hotkeys jump to next track (F2) vs. follow cursor (automatic scroll of playlist) (Read 1383 times)
March 08, 2020, 00:24:59 »
tommik128
Карма: +1/-0
Hi,
in short: what works with buttons does not seem to work with hotkeys
When there are more items in a playlist that requires scrolling down and up, the AIMP does not seem to "follow the cursor" meaning you eventually scroll out of the window. At least when using hotkeys (F1 / F2). It works when you press F3 first to activate the search text field. If you click with your mouse on the song it stops to work again. It seems to work fine with buttons on the player's main windows, but not with the hotkeys...
plus: It would be nice if there was an option to set this - follow the cursor (or active playing song) (automatic scroll of the playlist)...
Suggestions
DennoN
