Всё почти идеально, но, Пожалуйста, добавьте:1) полосу прокрутки в закладки:2) крестик очистки результатов в строку поиска. //Everything is almost perfect, but, please add:1) bookmark scroll bar:2) cross the cleaning results in the search bar.
can you describe and describe the errors with picture?Maybe I can fix it.sample:
1) scroll bar in bookmark items.fastpic СПАММ[/color].ru/]2) button to clear the search results.fastpic СПАММ[/color].ru/]You can do? This is the only thing missing.
I tried again and againThey're already coming out.As shown in picture If the problem is not resolved, you can download it from this site.https://www.deviantart.com/memo-se/art/Windows-8-Colors-Skin-For-Aimp-Player-489209927
OK I figured I'll try to fix it
Thanks for attention! Look forward to.
OK, Fixed
Okay, I fixed it for him.
Yes! Yes!Perfect! Thank you very much!
