English pages
Tutanhomon
[?] [2115] unplayable Opus file after editing tags with ATE
Topic: [?] [2115] unplayable Opus file after editing tags with ATE (Read 2335 times)
February 20, 2019, 14:52:23 »
ᛤᚤᛠᛥⴲ 👽
Карма: +76/-1
Hi,
I've found another bug. If I edit tags of an Opus file with AIMP's Tag Editor utility, the file becomes unplayable and it even makes crash Windows Explorer.
Here you have
a folder with 2 files: the working
1_BEFORE.opus
file and the not working
2_AFTER.opus
file.
Regards.
Last Edit: February 20, 2019, 19:35:33 by Artem
Re: AIMP v4.60 Beta 2, build 2115: unplayable Opus file after editing tags with ATE
February 20, 2019, 19:32:33 »
sveakul
Карма: +65/-0
I tried playing 2_AFTER.opus in AIMP 4.60.2115 beta2 and 4.51.2084, and it played fine in both, incl. lyrics display (looks like adding lyrics was the change you made). Also played OK in Foobar. Checked it with opusinfo.exe and no errors are shown. OS here is Windows 7 SP1 32-bit.
February 20, 2019, 19:35:11 »
Супермен
Карма: +2734/-48
I have tried to reproduce an issue on your files, but failed - all works fine.
What you mean under crash the Windows Explorer? Explorer does not support OPUS tags.
English pages
Tutanhomon
