Планы на 2020 год
English pages
Tutanhomon
How do I prevent files from being deleted?
Topic: How do I prevent files from being deleted? (Read 1721 times)
May 12, 2018, 21:17:34 »
Juan Montano
Good afternoon. I would like to know how I avoid having files deleted, songs deleted. There should be a jukebox complement, which avoids the deletion of files. Thank you.
Re: How do I prevent files from being deleted?
May 12, 2018, 21:19:03 »
Супермен
Карма: +2730/-48
What you mean? When and where files are deleted?
May 15, 2018, 19:50:30 »
Juan Montano
Hi, when you select a file, any of the playlist by right clicking gives the option to delete. Any user who uses my computer can delete any file from the hard drive. There is no option to block palication. Thank you.
May 15, 2018, 22:24:06 »
Супермен
Карма: +2730/-48
But any use can delete every file from you PC via Windows Explorer
May 16, 2018, 00:43:07 »
Juan Montano
But there are other applications that block the deletion of files and only the administrator has the privilege. Mediamonkey before I left it when it was run as administrator. Thank you.
May 16, 2018, 07:51:35 »
Супермен
Карма: +2730/-48
So, in this case aimp will not delete files from disk
English pages
Tutanhomon
