Suggestions
Player
DennoN
Фагот
Window title
Poll
Ваше мнение?
За
1 (33.3%)
Против
0 (0%)
Нейтрален
2 (66.7%)
Total Members Voted:
3
Topic: Window title (Read 4803 times)
Window title
August 15, 2017, 13:52:09 »
Forecaster
Is it possible to customize the window title similarly to the info bar/playlist titles?
The answer appears to be no. Could this feature be added?
I'm using the window title to get the currently playing song and would like the album included in that text.
Re: Window title
August 15, 2017, 13:55:11 »
Супермен
Карма: +2830/-49
No, it cannot be customized now.
I have moved your topic to suggestions board
Re: Window title
August 15, 2017, 14:41:18 »
Forecaster
I found the "copy current song info to clipboard" feature and I've made my script execute the hotkey and then get the contents of the clipboard if the selected window matches AIMP's window class, otherwise it'll use the window title (if the selected window is for example a browser window).
So it's not super critical anymore.
That said it's not ideal, because it requires executing a hotkey it interferes slightly with other programs. Getting the title would be a lot better since it is completely unnoticeable.
Last Edit: August 15, 2017, 16:28:42 by Forecaster
Re: Window title
August 16, 2017, 14:03:38 »
Forecaster
Turns out having something constantly overwrite the clipboard is pretty annoying... I'm going to go back to using the window title for now and hope it becomes customisable soon...
Re: Window title
October 03, 2017, 21:16:37 »
Forecaster
Something else that would work is AIMP simply updating a text file according to a pattern when the current song changes.
The script just grabs the title and writes it to a text file, which OBS then reads.
Last Edit: October 17, 2017, 17:58:10 by Forecaster
Suggestions
Player
DennoN
Фагот
Window title
