Исправил баги, убрал пару костылей и хвосты, желательно обновиться до версии 2.7.1
Here's the V 2.7 French localisation file.It would be very useful to indicate on the first page (https://www.aimp.ru/forum/index.php?topic=54154.0) the list of languages included in the A4 file available for download.ThanksBlanchon
It was done probably to increase contrast. For me dark theme now is also a little too black, but in 2.6 there was a bit too low contrast. Now I would set the darkness between 2.6 and 2.7, and lightly brighten the font text.And btw, "Templates for static labels" option is not working with Classic layout.
Hello!This is a Japanese translation for A4 2.7.1Thanks for all your good work.
Здравствуйте. Можно ли сделать опцию, включение которой сделает расстояние между вкладками списка плейлистов, в раскладке макета "левый столбец" или "правый столбец", более компактным, чтобы в столбце помещалось больше вкладок? Или сделать межстрочное расстояние настраиваемым, если такое возможно.
Thanks, 2.7.2 suggestions/bugs:1. No track info when there is no ID3v1 & v2 tags in audio file with these templates https://i.imgur.com/rIWuqcK.png: - in main player when "Templates for static labels" in skin settings is disabled: https://i.imgur.com/dUuNwYh.png- in miniplayer https://i.imgur.com/THWlQZG.png2. The space for the track info in the miniplayer is too small (when miniplayer is the shortest in nav buttons always visible mode) https://i.imgur.com/ZJutbMc.png, especially when "Stretch to width" is disabled https://i.imgur.com/dPQRCiS.png. Perhaps it would be possible to widen it twice at the expense of the slider/wave?3. Some problems with the initial duration label and track navigation (can't click the bar at the beginning) https://i.imgur.com/wL3NzAM.gif. No such problem in miniplayer.4. Track repeat and Shuffle label doubled https://i.imgur.com/jzyo8Ii.png 5. Progress bar in miniplayer not working? https://i.imgur.com/0pTvewK.png6. Longer bottom margin in Basic and Additional tabs https://i.imgur.com/x6XMljJ.png7. Still no Music Library button ;]
