Try to use control Panel instead of background element Container/TabbedGroup (third item on Component Palette). See Help - Skin Structure - Controls - Panel.Or try to set negative value to property AlignmentMargins for Container and/or TabbedGroup.
Now, how to show for example content number 3 in 5 tabbedgroup with 1 button only?
Use custom provider - LogicalOperatorCounter. Bind counter value to tabbed group. Via button you will set value for counter.
But no option in tabbedGroup bindings editor
Oh, you are right. You can bind each sub-container in all tabbed groups to counter's value (Visibility to Position) and specify an expression of binding links.
