%аppDаta/AIMP3 (Ini) files are the interface If you delete a file, you can fix it or I'm using AIMP 3.55 build 1345 on a low error rate
а ещё можно нарисовать не кривой скинлибо написать об ошибках AIMP, если вы их нашли, когда собирали скин
Hello memo-se. Thanks for the skins. Great job!From all your skins the most adorable is Win-8Colors.This Aimp Modern is also good.But please, see the picture below, may be you can fix it.1. I don't like the visualization in the middle of main window playing.Add a button to stop it.2. When a file is playing from the playlist then the active tab must be highlighted, normally.Finally, would you be so kind to add a detachable visualization window to every of these skins: Windows Media Player 11, Mirillis Splash, and Splash Ex. Thanks.
Hello. Thank you for this new version of the Aimp Modern.Very pleasant to use it now. I got it on deviantart. But here is still previous version.You should say to moderators to change it.So, I did not expect that you will make these changes so quick.You are an unordinary man. And, if you don't mind, see my last request about other skins. And I will not forget to thank you.May you achieve a series of desired outcomes from the many things you attempt in life!
Кнопку записи и индикатор запилите плиз. А то только с пульта можно запись начать
No record button
