#include "stdafx.h"#include "AIMPSDKCommon.h"#include "AIMPSDKRemote.h"#include <conio.h>#include <iostream>using namespace std;HWND FAIMPWindow;int _tmain(int argc, _TCHAR* argv[]){ FAIMPWindow = FindWindow(AIMPRemoteAccessClass, AIMPRemoteAccessClass); if (!FAIMPWindow) cout<<"No"; else cout<<"Yes"; _getch(); return 0;}
FAIMPWindow = FindWindow((LPCWSTR)AIMPRemoteAccessClass, (LPCWSTR)AIMPRemoteAccessClass);
FAIMPWindow = FindWindowA(AIMPRemoteAccessClass, AIMPRemoteAccessClass);
int AIMPGetPropertyValue(int APropertyID){ if (FAIMPWindow) return SendMessageW(FAIMPWindow, WM_AIMP_PROPERTY, APropertyID | AIMP_RA_PROPVALUE_GET, 0); else return 0;}
#include "stdafx.h"#include "AIMPSDKCommon.h"#include "AIMPSDKRemote.h"#include <conio.h>#include <iostream>using namespace std;HWND FAIMPWindow; //AIMPint AVersion; //Versionint AIMPGetPropertyValue(int);int _tmain(int argc, _TCHAR* argv[]){ //Find AIMP FAIMPWindow = FindWindowA(AIMPRemoteAccessClass, AIMPRemoteAccessClass); if (FAIMPWindow) { AVersion = AIMPGetPropertyValue(AIMP_RA_PROPERTY_VERSION); cout<<AVersion; } else cout<<"AIMP not running"; _getch(); return 0;}int AIMPGetPropertyValue(int APropertyID){ if (FAIMPWindow) return SendMessageW(FAIMPWindow, WM_AIMP_PROPERTY, APropertyID | AIMP_RA_PROPVALUE_GET, 0); else return 0;}
// Returns player version: // HiWord: Version ID (for example: 301 -> v3.01) // LoWord: Build Number AIMP_RA_PROPERTY_VERSION = $10;
// AIMPvvv.cpp: определяет точку входа для консольного приложения.//#include "stdafx.h"#include "AIMPSDKCommon.h"#include "AIMPSDKRemote.h"#include <conio.h>#include <iostream>#include <limits>using namespace std;HWND FAIMPWindow; //AIMPDWORD AVersion; //Versionint AIMPGetPropertyValue(int);bool AIMPSetPropertyValue(int , int);int _tmain(int argc, _TCHAR* argv[]){ //Find AIMP FAIMPWindow = FindWindowA(AIMPRemoteAccessClass, AIMPRemoteAccessClass); if (FAIMPWindow) { //AVersion = AIMPGetPropertyValue(AIMP_RA_PROPERTY_VERSION); //cout<<((AVersion & 0x00FF)|(AVersion & 0xFF00)); HANDLE AFile; HANDLE _AInfo; TAIMPFileInfo *AInfo; string S; string ABuf; AFile = OpenFileMappingA(FILE_MAP_READ, TRUE, AIMPRemoteAccessClass); _AInfo = MapViewOfFile(AFile, FILE_MAP_READ, 0, 0, AIMPRemoteAccessMapFileSize); AInfo = (TAIMPFileInfo*)_AInfo; cout<<AInfo->FileSize<<endl; cout<<AInfo->BitRate<<endl; cout<<AInfo->Artist; } else cout<<"AIMP not running"; _getch(); return 0;}int AIMPGetPropertyValue(int APropertyID){ if (FAIMPWindow) return SendMessage(FAIMPWindow, WM_AIMP_PROPERTY, APropertyID | AIMP_RA_PROPVALUE_GET, 0); else return 0;}bool AIMPSetPropertyValue(int APropertyID, int AValue){ if(FAIMPWindow) return SendMessage(FAIMPWindow, WM_AIMP_PROPERTY, APropertyID | AIMP_RA_PROPVALUE_SET, AValue); else return false;}
#include <Windows.h>#include <stdio.h> #define AIMP2_RemoteClass L"AIMP2_RemoteInfo"#define AIMP2_RemoteClassSize 2048 #pragma pack(push, 1)typedef struct _AIMP2FileInfo{ DWORD cbSizeOf; // BOOL nActive; DWORD nBitRate; DWORD nChannels; DWORD nDuration; INT64 nFileSize; DWORD nRating; DWORD nSampleRate; DWORD nTrackID; // DWORD nAlbumLen; DWORD nArtistLen; DWORD nDateLen; DWORD nFileNameLen; DWORD nGenreLen; DWORD nTitleLen; // PWCHAR sAlbum; PWCHAR sArtist; PWCHAR sDate; PWCHAR sFileName; PWCHAR sGenre; PWCHAR sTitle;} AIMP2FileInfo, *PAIMP2FileInfo;#pragma pack(pop) int __cdeclwmain(){ HANDLE hAIMP; PAIMP2FileInfo aimpFileInfo; LPWSTR pBuff; hAIMP = OpenFileMapping(FILE_MAP_READ, FALSE, AIMP2_RemoteClass); if ( !hAIMP ) { wprintf(L"error %d\r\n", GetLastError()); return 1; } aimpFileInfo = (PAIMP2FileInfo)MapViewOfFile(hAIMP, FILE_MAP_READ, 0, 0, AIMP2_RemoteClassSize); if ( aimpFileInfo ) { WCHAR buff[256]; #define WRITE_TO_BUFF(x) \ memcpy(buff, pBuff, (x) * 2); \ buff[x] = '\0'; \ pBuff += (x); // В pBuff вся остальная информация, разбивайте её испольуя поля nAlbumLen (и т.п.) // из структуры aimpFileInfo pBuff = (LPWSTR)((PBYTE)aimpFileInfo + aimpFileInfo->cbSizeOf); wprintf(L"%d Hz, %d kbps, %d chans\r\n", aimpFileInfo->nSampleRate, aimpFileInfo->nBitRate, aimpFileInfo->nChannels); wprintf(L"%d seconds, %d bytes\r\n", aimpFileInfo->nDuration / 1000, aimpFileInfo->nFileSize); WRITE_TO_BUFF(aimpFileInfo->nAlbumLen) wprintf(L"Album: %s\r\n", buff); WRITE_TO_BUFF(aimpFileInfo->nArtistLen) wprintf(L"Artist: %s\r\n", buff); WRITE_TO_BUFF(aimpFileInfo->nDateLen) wprintf(L"Date: %s\r\n", buff); WRITE_TO_BUFF(aimpFileInfo->nFileNameLen) wprintf(L"File name: %s\r\n", buff); WRITE_TO_BUFF(aimpFileInfo->nGenreLen) wprintf(L"Genre: %s\r\n", buff); WRITE_TO_BUFF(aimpFileInfo->nTitleLen) wprintf(L"Title: %s\r\n", buff); UnmapViewOfFile(aimpFileInfo); } CloseHandle(hAIMP); system("pause"); return 0;}
type PAIMPFileInfo = ^TAIMPFileInfo; TAIMPFileInfo = packed record StructSize: DWORD; // SizeOf(TAIMPFileInfo) // Active: LongBool; BitRate: DWORD; Channels: DWORD; Duration: DWORD; FileSize: Int64; Mark: DWORD; SampleRate: DWORD; TrackNumber: DWORD; // AlbumLength: DWORD; ArtistLength: DWORD; DateLength: DWORD; FileNameLength: DWORD; GenreLength: DWORD; TitleLength: DWORD; // Album: PWideChar; Artist: PWideChar; Date: PWideChar; FileName: PWideChar; Genre: PWideChar; Title: PWideChar; end;
IAIMPAddonsPlayerManager = interface(IUnknown) [SID_IAIMPAddonsPlayerManager] function PlayEntry(AEntry: HPLSENTRY): HRESULT; stdcall; function PlayFile(AFileName: PWideChar; AFailIfNotExistsInPlaylist: LongBool): HRESULT; stdcall; function PlayStorage(ID: HPLS; AEntryIndex: Integer = -1): HRESULT; stdcall; // Register / Unregister custom FileInfo repository, you can put own info about the any file function FileInfoRepository(ARepository: IAIMPAddonsFileInfoRepository; ARegister: LongBool): HRESULT; stdcall; // if AFileName = nil: Get information about currently playing file function FileInfoQuery(AFileName: PWideChar; AInfo: PAIMPFileInfo): HRESULT; stdcall; // Register / Unregister custom playing queue controller function PlayingQueueController(AController: IAIMPAddonsPlayingQueueController; ARegister: LongBool): HRESULT; stdcall; // see AIMP_CFG_PATH_XXX function ConfigGetPath(AConfigPathID: Integer; ABuffer: PWideChar; ABufferSizeInChars: Integer): HRESULT; stdcall; // see AIMP_SUPPORTS_EXTS_XXX function SupportsExts(AFlags: DWORD; ABuffer: PWideChar; ABufferSizeInChars: Integer): HRESULT; stdcall; end;
var finfo: TAIMPFileInfo; i: longbool;begin ZeroMemory(@fInfo, SizeOf(fInfo)); // Не уверен, правильно ли это? fInfo.StructSize := SizeOf(fInfo); // И вот это i := false; if AUserData.FFrame.PlayerManager <> nil then AUserData.FFrame.PlayerManager.PlayFile('D:\Downloads\Музыка\e84df0f642a5.mp3', i); // Трек переключается => плеер инициализирован try if Succeeded(AUserData.FFrame.PlayerManager.FileInfoQuery(nil, @fInfo)) then // Возвращает false begin MessageBox(0, fInfo.Artist, fInfo.Title, MB_OK); {Plugin.SendInfo( //Чисто моя функция FileInfo.Artist, FileInfo.Title, FileInfo.Genre, ); } end else MessageBox(0, 'not Succeeded', ' ', 0); except on E : Exception do MessageBox(0, PWideChar(E.Message), PWideChar(E.ClassName), MB_OK); end;
В чем может быть ошибка? Плеер однозначно инициализирован. Так как трек переключается. А вот почему не хочет отдавать/принимать FileInfo я не понимаю. Дебаггером пользоваться не умею, всё время работал с C# и Java.
Нет, отладчик там есть, но он совсем по-другому устроен. Тебе не нужно смотреть код ассемблера и значения ячеек в памяти, все это делает за тебе MS Visual Studio. Все, что ты делаешь - ставишь breakpoint'ы, нажимаешь "Старт" (либо присоединиться к процессу, если речь идет о dll) и среда останавливается, показывает сразу значения переменных, условных операторов, и прочее. Более человечно все-таки, я считаю. Может даже иногда показать, где допущена ошибка. А анализатор кода настолько мощный, то сразу все возможные неприятности расскажет и покажет.
