Questions (archive)
коды ошибок воспроизведения (модуля BASS)
Topic: коды ошибок воспроизведения (модуля BASS) (Read 22362 times)
October 12, 2010, 20:19:04 »
Супермен
Карма: +413/-72
Тема на время, пока используется BASS модуль
Error codes list (Code list)
#BASS_OK =0 ;all is OK
#BASS_ERROR_MEM =1 ;memory error
#BASS_ERROR_FILEOPEN =2 ;can't open the file
#BASS_ERROR_DRIVER =3 ;can't find a free/valid driver
#BASS_ERROR_BUFLOST =4 ;the sample buffer was lost
#BASS_ERROR_HANDLE =5 ;invalid handle
#BASS_ERROR_FORMAT =6 ;unsupported sample format
#BASS_ERROR_POSITION =7 ;invalid playback position
#BASS_ERROR_INIT =8 ;BASS_Init has not been successfully called
#BASS_ERROR_START =9 ;BASS_Start has not been successfully called
#BASS_ERROR_ALREADY =14 ;already initialized
#BASS_ERROR_NOCHAN =18 ;can't get a free channel
#BASS_ERROR_ILLTYPE =19 ;an illegal type was specified
#BASS_ERROR_ILLPARAM =20 ;an illegal parameter was specified
#BASS_ERROR_NO3D =21 ;no 3D support
#BASS_ERROR_NOEAX =22 ;no EAX support
#BASS_ERROR_DEVICE =23 ;illegal device number
#BASS_ERROR_NOPLAY =24 ;not playing
#BASS_ERROR_FREQ =25 ;illegal sample rate
#BASS_ERROR_NOTFILE =27 ;the stream is not a file stream
#BASS_ERROR_NOHW =29 ;no hardware voices available
#BASS_ERROR_EMPTY =31 ;the MOD music has no sequence Data
#BASS_ERROR_NONET =32 ;no internet connection could be opened
#BASS_ERROR_CREATE =33 ;couldn't create the file
#BASS_ERROR_NOFX =34 ;effects are not available
#BASS_ERROR_PLAYING =35 ;the channel is playing
#BASS_ERROR_NOTAVAIL =37 ;requested Data is not available
#BASS_ERROR_DECODE =38 ;the channel is a "decoding channel"
#BASS_ERROR_DX =39 ;a sufficient DirectX version is not installed
#BASS_ERROR_TIMEOUT =40 ;connection timedout
#BASS_ERROR_FILEFORM =41 ;unsupported file format
#BASS_ERROR_SPEAKER =42 ;unavailable speaker
#BASS_ERROR_VERSION =43 ;invalid BASS version (used by add-ons)
#BASS_ERROR_CODEC =44 ;codec is Not available/supported
#BASS_ERROR_ENDED =45 ;the channel/file has ended
#BASS_ERROR_UNKNOWN =-1 ;some other mystery error
http://un4seen.com/bass.html
Last Edit: February 06, 2013, 18:08:35 by Soolo
Questions (archive)
