Опрос 2024
How to tell AIMP for Android to look on 32GB storage for its mp3s?
Topic: How to tell AIMP for Android to look on 32GB storage for its mp3s? (Read 5000 times)
February 03, 2018, 18:45:19 »
1Steven
Продвинутый
Hi. I am using the TZE Quest N817 (very low internal memory) that comes with Android KitKat 4.4.4, and I installed AIMP for Android this week. I have been using AIMP on Windows 10 for some time.
I thought I copied my MP3s onto the 32GB storage but in any case now they are in Music in internal memory and on the 32GB (let's call it).
AIMPa runs fine. I looked in the settings but didn't see anything that would help. When I pressed the icon with 3 vertical dots in the upper right corner, it said "There is nothing playing now." So I am left at a standstill.
I wonder if AIMPa uses a library and that's what's in internal memory. I'll leave it there for now. So, could you tell me e.g., how I set the default music location to a folder on the 32GB? Also, since the mp3s are in both places, I don't know why it doesn't see them or how to point to them.
Thanks,
Steven
Re: How to tell AIMP for Android to look on 32GB storage for its mp3s?
February 03, 2018, 20:35:24 »
Супермен
Карма: +2928/-56
AIMP for Android does not have a library for now, playlists only. the "3 dots icon" is menu of current screen. You can switches between screens via gestures or via navigation menu ("3 lines icon"). So, you should switch to playlist screen and add your music to it.
