In the standard Skins skin, the same bug!
Hello, I love this skin, but it uses too much CPU and my laptop gets noisy by the coolers, when it's on the main interface.
Turn off the slider Blur and the item Spectrum
The Alt. wave Track progress bar, makes the skins looks really cool, and that's one of the reasons I use it, LOL. The item Spectrum is already disabled, I never turned it on. The thumb slider is in Mode 1, as default value, never changed it either. I see no changes on the skin if I change it. I think Mode 1 is OFF.
Turn off blur
Did it. Turned off blur, album cover, and also background image, and CPU usage is still between 11-13%...(The skin looks so much better with all those things enabled).
More performance gainsmy test (enabled)my test (disable)
build 2083, скин v 1.3, шапка выглядит так
Quote from: Ertostyk on February 26, 2018, 16:50:05Что-то я не вижу у вас вариантов скина. Кнопка скачать одна, в архиве один скин Я имею ввиду в каталоге тут на сайте, тут же много их всяких разных, помимо моих
